Perform this procedure to configure Multi-area SPB Layer 3 static I-SID routed multicast redistribution policy in the remote area.
Routed multicast redistribution is available for IPv4 only. With the MAC learning disabled, the static data I-SID multicast redistribution policy takes precedence over the Layer 2 multicast redistribution.
  1. In the navigation pane, expand Configuration > Fabric.
  2. Select MultiArea.
  3. Select the L3 MC Redist Remote Static ISID List tab.
  4. Select Insert.
  5. In the Type field, select staticisid.
  6. Select Enable.
  7. In the IsidListName field, type the name of the I-SID list.
  8. In the Apply field, select apply.
  9. Select Insert.
Use the data in the following table to use the L3 MC Redist Remote Static ISID List tab.
Name
Descriptions
Type
Specifies the layer 3 static I-SID routed multicast redistribution type. The default type is staticisid.
Enable
Enables layer 3 static I-SID routed multicast redistribution in the remote area. The default value is disabled.
IsidListName
Specifies the name of the I-SID list. The default I-SID list name is htr.
Apply
Applies the Multi-area SPB layer 3 static I-SID routed multicast redistribution filters in the remote area. The default value is noAction.
